Results 1 to 2 of 2
    McDowell's Avatar
    Feb 2019
    Zamunda
    Default Honda Accord 2011 Power Steering Control Repair
    Hello mates,
    I am after some help with this unit.
    I am havind DTC 81-03 Yaw Rate Sensor Failure. Do you know is this is a common problem and how to can I fix or if unit can be swap or needs to be coded.
    70b80f12-0f7c-4375-b11c-e67178eacdb7.jpgb3fad7dc-240a-43a7-8a44-b36e8b426f77.jpgc2bf35e6-e46d-457b-ac61-1b17ed24f268.jpg
    Thank you so much in advance
    alex_r_2001's Avatar
    New Jersey ,, USA
    Quote Originally Posted by McDowell View Post
    Hello mates,
    Yaw rate sensor is apart from power steering its used for abs srs power steering and many other ecu's... from what i checked its used in 2 different locations.... 3.5 with navigation its built into navigation unit... without navigation here are some pictures of where its located..
    With vin # I can give definitive location
    Please press thanks button if this helped out..
  3. The Following User Says Thank You to alex_r_2001 For This Useful Post:
    McDowell (27th August, 2020)
