    Jul 2015
    Default Marelli MJ8F3H MJ8F3HW20P , need coding from Automatic Gear box to Manual
    Hi guys,
    Recently i performed an IMMO OFF in this ECU. The inmo OFF seems good, but the car not start correct all times and someones won´t star.
    No immo DTC relates codes.
    THe only problem (I belive) is the used ECU coming from an automatic model and not recognaize "P".
    Any one Knows how to coding the information in the ecu?
    My car ins a Fiat fiorinno but the ECU come frome a Citoren NEMO. May be with Citroen OEM tool????'
    Thanks in advance
    Meat-Head's Avatar
    Wont argue with you *TRY* fill eeprom with 00
    install into car, ignition on DO NOT TOUCH ANY PEDALS for 5 minutes
    then ignition off, read eeprom, what is changed cut and paste into your good dump
    and run.
    try not to trip over dk thanks button, you have plenty to spare
  3. The Following User Says Thank You to Meat-Head For This Useful Post:
    MadridEcu (3rd September, 2020)
    dimitar's Avatar
    Its not just coding you need to change flash for manual transmition
    50w Soldering Iron
    Chisel
    Sometimes Hammer
  5. The Following User Says Thank You to dimitar For This Useful Post:
  6. #4
    Jul 2015
    Thanks to both of you, at the end i bought an used manual ECU for 70€.... May be if i readed this before i try your method. I will post my results with the used ECU in any case and compare the files.
    Meat-Head's Avatar
    Yes read and upload no password. Would be a great topic for a Sunday afternoon picnic
  8. The Following User Says Thank You to Meat-Head For This Useful Post:
    MadridEcu (18th September, 2020)
  9. #6
    Jul 2015
    Meat-Head again. I do a new inmo off in the "new" used ECU and car still with the problem based on this we discard ECU problems. I think the problem was that the engine becames from a donor car and last owner maybe not bought same engine. But after discard ECU my customer didnt continue in my garage with the diagnostic because he is a mechanic and prefers continuo himself.
