Results 1 to 13 of 13
    Aug 2009
    Default Xhorse VVDI Super Chip XT27 Feedback problematic
    I have some problem with this superchip.
    1) Ssangyong clone 4D,Pprepare x27 and clone with vvdikey car start and work 2-3 day and stop to work, Chenge with 4d-4c xhorse chip and work normal
    2) Peugeot 206 prepare 7935 id45 programming with lexia, car start and work 20 day and stop to work, i use ori 7935 and precode to id45 and work normal.
    if someone have similar problem please share there, which car and chip.
    p1et's Avatar
    Oct 2013
    There is saying 'if one thing is for all things, it must be trash'
    And this saying perfectly fit ti this situation. How come universal transponder which can emulate almost everything, can be reliable? I don't believe it and I also heard multiple identical situations like you described.
    I would never use such chip, I want to sleep well and avoid customer comebacks at all cost.
    For OBD programming I use only genuine chips and for cloning (which I do rarely) I use dedicated chips ex. i'm cloning 4D on TPX2 or CN2, 46 chips for TPX4 or CN3. LKP chips are also shit.
  3. The Following User Says Thank You to p1et For This Useful Post:
    musti418 (29th November, 2020)
    Mar 2018
    UK
    I use XT27 daily and never had problems
    I copy every chip that is possible
    For me is better if some key will stop work than the car died in my hands
  5. The Following User Says Thank You to Manta1600 For This Useful Post:
    PierreTheron (27th August, 2020)
  6. #4
    PierreTheron's Avatar
    Aug 2009
    Centurion,South Africa
    xt27 is reliable m8 .even xhorse does not know how to prepare it perfectly so that it will work for years .
    The guy behind the tool must know how to prepare it so that it will start the car for years to come.
    So there is tips and tricks that you must learn in trade as a locksmith..
  7. #5
    rob h's Avatar
    May 2011
    Pcf7935, dont use the superchip.
    All others are fine.
    And If you glew any off these carbon like transponders,
    Some dissolve.
    A regular keyhead, some are air tight when closed.
    Leaving the glue not to set quick.
    This might lead to a still readable transponder,
    Only Weaker in strenght.
    I dont use superglue, the fumes leave White stains.
    Regular glues are more suited, if applied to a minimum.
  8. #6
    Nov 2018
    Ive found super chips are excellent and quite strong unlike some other universal chips e.g. handy baby which Ive found really poor especially on 4d67 etc.
    Sometimes you still need original chips e.g. when generating 7935 ID40 they don't work. Programmer appears to program to car they dont work properly.
    glue is very poor. Use Black tack. You use a tiny amount in each key to secure chip.
  9. #7
    Feb 2010
    Quote Originally Posted by Brat View Post
    which type Ssangyong you did?
    For Tivoli was not possible to even read 4D for cloning...
    Boras
  10. #8
    p1et's Avatar
    Oct 2013
    Quote Originally Posted by Boras View Post
    Boras
    I would answer you why but 10 years on forum and no single thanked, makes me leave this without further explanation
  11. #9
    Jan 2016
    I order the next batch of XT27 and the chip was of poor quality.
    I try to copy renault logan and lada granta (both 7936)
    Copies can not start the car
    Also i try to program XT27 directly to car but failure
    Chips were determinated by Key Tool Mini as XT27
    Chips were tagged:
    XT27A
    C252019 C252020 C252021 C252022 C252023 C252026
  12. #10
    Jan 2018
    Quote Originally Posted by kostin View Post
    Chips were tagged:
    XT27A
    i did a logan did not have problem, but i had a problem on bmw turns out it was the distance when i held it near the antena it worked just saying for info
  13. #11
    Jan 2016
    With previos batches of XT27 i do not have any problem
    But this one is poor quality-((
    XT27 have weak sensitivity
  14. #12
    Faraday's Avatar
    May 2012
    The dark side of the moon
    I use it every day and had no problem.
    I did few cars with emulated 7935 in example Opel, Renault.
  15. #13
    Jun 2017
    US
    Only have had issues cloning gm 46e chips. Work for a week and then you get a call back.
    Ford C chips don't work most the time either because the original glass chips have greater range and super chip can't reach.
