write. pass pm
write. pass pm
FILE SERVICE
pioneer427 (28th August, 2020), REPAI ECU (22nd June, 2022)
Hi.
Hyundai i20 1300 Benzin ME17.9.21 TC1724
I have a similar problem with the catalyst.
CAT OFF, please ...
Errors P2096 and P0420 ------- ->>>> Problem SOLVED <<<<<< -
THX T H X
Attachment 801358Could you help me with disabling DTC - P0420.
Thanks in advance.
[QUOTE = pioneer427; 3942002] Xin chào
, tôi cần E2 cho
PHIÊN BẢN PHẦN MỀM kia rio: FBX65C4DSRRSO3G1
PHẦN CỨNG SỐ: 9003140245
PHẦN MỀM: ECKN03F5
PHIÊN BẢN PHẦN MỀM: FBX65C4DSRRSO3G1
Cảm ơn! [/ TRÍCH DẪN]
i need pass, thank
Guys I have a question. I need P2096 and P0420 off in ME17.9.21 0261S12964. Is what "pioneer427" call E2 the same thing? Essentially what is "E2"? Secondly is this procedure proven to be working as intended? The cars run OK with no issues? I have been informed that this ECU is making the car running rich after this.
If DTCs P2096 and P0420 are off, this is not enough and the algorithms continue to protect the catalyst by enriching the mixture. but there is an ECU where it is enough to turn off the fault code
Pioneer427 posted the correct solution, I give the source file, be sure to compare the source file with your file
