Work fine thanks diego.
Of course i'm in over boost : 3300 mbar my bad
What is the max boost for a 1756 vk 3100 mbar ?
I notice for specified boost some deviation. I changed only UACC_ESBNormVal from 120 to 140 fpr 25 and 26
I wonder if Sig_pDIAScale_C factor is the same for both actual and specified boost values ?
I corrected all factors below : from 0.00983 to 0.0714 and a value from 120 to 140 .
Requested boost value seen to be more corect now ?!
1C127E- Skalierung Umrechung SG->DSM für Druck- Sig_pDSMScale_C
1C1418- Skalierung fuer ASMOD Druck Umrechung SG -> DSM- Sig_pASMODDSMScale_C
1C1420- Skalierung fuer ASMOD Druck Umrechung SG -> DIA- Sig_pASMODDIAScale_C
Otherwise, I'm NOT able to archive a smooth boost curve and wonder how to process :
- Rescaling main N75 maps IQ axys for more fine tuning ?
- Or dealing with PID controler ?
I'm still not able to figure out the Requested boost value on vcds .
I wonder where is located Sig_pDSMScale_C for this messuring block ? !
And my boost is it not steady...
Diego I'm In the dark
My "requested boost" value is still wrong, I hope the "actual" value is accurate otherwise my turbo will blow rapidly ....
I'm reaching pd 130 injectors limits and think about bigger items .
Any advices are welcome.
Diego please don't be shy, I try to do my best based on your advices but as you know i'm slow
All of your posts help me a lot !!
