Results 1 to 8 of 8
    Aug 2020
    Default Ecu Hardware Problem
    hi need help i had Me9.7 Ecu that not working when put switch On car radiator Fan spinning heavy and fast car not start not crank .... help to know the problem.
    alex_r_2001's Avatar
    New Jersey ,, USA
    check for bad capacitor... check for 5v reference voltage..... check can hi-lo for 2.3- 2.6 volts if you have old computer for parts laying around replace the can transceiver 8 pin IC ... TJA1050
    but before you go into the ecu make sure all powers and grounds are present at ecu connector....
    make sure to check computer datalines with ecu connected and also with ecu removed...
    If this helped dont forget press thanks button and some reputation
    Aug 2020
    see that Chip i measure it provide 5v and 3v to the flash and Mpc and Ecu read clear and CAN bus receive those voltage normally but no 5voltages on Sensors ....
    Apr 2017
    High fan speed, leads to internal MCU error or does not recognize the mapping area.
    May 2016
    Quote Originally Posted by Abcparty View Post
    Correct, in my case, under the MCU the tracks were all broken.
    New Jersey ,, USA
    Quote Originally Posted by blackground View Post
    Nice to know you found problem... Did you repair????
    Also If my post help don't forget press thanks and reputation button ...
    Aug 2020
    nice discussion so we need to know if it can be repaired or what extra to solve the problem?
    May 2016
    Quote Originally Posted by alex_r_2001 View Post
    No, in my case i buy a new ECU.
