If someone could help me with Mercedes seed calculator .dll library
In specially ic204.dll need to do some manual coding on my w204
Do you want to change mileage?
No ,only to activate amg menu by seed
Solved, I managed to source out an ic204.dll for unlocking the KI ,as for the seed calculator I had it from a back while
If someone needs ic_204.dll here it is
If it helped press thanks
bhering (3rd April, 2022), BlackJakePL (4th June, 2024), borislavpixely (16th October, 2024), dgtl (6th June, 2022), Eraz3r (3rd March, 2024), fanatik67 (7th May, 2023), geiti94 (3rd March, 2021), jakubnowak717 (16th April, 2024), junho2696 (21st May, 2024), lerogol450 (15th April, 2024), mbwag (23rd September, 2020), mercedesmods (20th April, 2022), ptalev (5th December, 2021), sokol1337 (1st December, 2021), stanislav georgiev (2nd March, 2024)
Why the seed calculator give Key length: 4 byte in answer? For AMG menu need 8
I really don't know, if anyone knows please share your opinion to help others
Im thinking that only the creator of the seed calculator can answer about the algorithm
I ve tested it and got the same short key... has anyone an idea?
would be really interested too
i need it!!!!!!!!!!!!!
hello, what security levels are there in this dll?
i think its only until level 5 but i will check it tomorrow
Searching for that for a long time, hope it is level 9 :|
Need that file so much!![]()
would someone share the ic_204 dll with access level 09?
