Is it 2016 or 2019? They look identical but not
The same. I have good flash dumps for both 2016 and 2019 if you need. Your files say 2019 which is why I ask 16 or 19?
good evening comrades i tried calibrating the mileage of this 2016 kia sorento my device read fine the cluster and gave me old mileage which is 139816km i then put in the figure i wanted which is 50xxx but everything on the cluster works perfect but mileage displays 0 and starts counting when you drive car can anybody give an idea on why its behaving like this post both old mileage file and calibrated file maybe someone can compare and come out something thamks
Also is the processor (BS) or (CS) at the end. Hugeeeeee difference. Don’t do this one by obd. Remove and solder. Which tool you using?
your file mod is not good edited, that ¡s the problem.
i was also thinking the same way because this cluster has a different look than the normal 16 i know of and mcu type is mb910f061bs
i think chassis might have been manipulated
Original file is good, only edited file has doble mileage inside (original and New).
MileageAudit5 (14th September, 2020)
Write this file with your DigiMaster and you will fix it.
skilion290 (2nd September, 2020)
a thousand thanks comrade worked like magic
Hello, Can you help me with file for this in .bin format?
I have one with corrupted obd read.
Hello M8
two files one from Miles one from Kilometer.
