Results 1 to 15 of 15
    Mar 2019
    Scandinavia
    Question Renault Master EDC16C36 error
    Bosch EDC16C36/0281013363
    Renault Master 2.5 dci 2007 m.y
    The customer have tried to code injectors with Delphi diagnostic and got "AAAAAA" instead of codes.
    The car start and stop after this....
    I have read Delphi diagnostic by obd on bench and have no errors, have read eeprom and flash/map file by Ktag. May be it is possible to
    flash virgin file?
    Hope someone know how to do it... I'm still learning
    learning by doing, learning by experience... please thx is I helped you
    Mar 2019
    Scandinavia
    Nobody have had this problem? Nobody have original file or virgin?
    rob h's Avatar
    May 2011
    Get a tool like clip to program the injectors.
    You do not need a new ecu file.
    Just need the correct tools
  4. The Following User Says Thank You to rob h For This Useful Post:
    Willinickersen (4th September, 2020)
    Mar 2019
    Scandinavia
    Okay, thank you very much for your reply.
    I will try to look for "clip".....
    London
    Post Eeprom dump and injector codes maybe someone here can help ..
    Pretty sure launch is capable of this task too !!!
  7. The Following User Says Thank You to shifty01 For This Useful Post:
    Willinickersen (5th September, 2020)
  8. #6
    Mar 2019
    Scandinavia
    I will do later. Thank you very much for your reply
  9. #7
    darrenhyland's Avatar
    Aug 2010
    IRELAND
    Don't waste your time with anything other than clip. Had this issue several times recently. Ended up using Reno clip which resolved the issue easily.
  10. The Following User Says Thank You to darrenhyland For This Useful Post:
    Willinickersen (7th September, 2020)
  11. #8
    Mar 2019
    Scandinavia
    Quote Originally Posted by darrenhyland View Post
    Okay, so you mean it is not possible to let someone on this forum to do this?
  12. #9
    Jan 2015
    You can write injector codes with galletto v54. after you can change with delphi. I made it yesterday renault 1.9 edc16c3. all ok.
    (I write scenic injetor codes file after change them with delphi)
  13. The Following User Says Thank You to gmendieta For This Useful Post:
  14. #10
    Mar 2019
    Scandinavia
    Thank you for your reply
  15. #11
    Mar 2019
    Scandinavia
    I haven't Galletto V54, is it possible with other tools? Have genuine Kess and I /O terminal tool
  16. #12
    Feb 2016
    romania
    Clip is the solution, i have cheap clone works every time, easy to use to! do not waste your time with anything else.
  17. The Following User Says Thank You to flekken For This Useful Post:
    Willinickersen (9th September, 2020)
  18. #13
    Mar 2019
    Scandinavia
    Thank you for your reply. Yes, but I have not Clip at this time.
  19. #14
    Mar 2019
    Scandinavia
    Exclamation
    Quote Originally Posted by shifty01 View Post
    Attatched eeprom read by KTag and codes for injectors in the text file.
  20. The Following User Says Thank You to Willinickersen For This Useful Post:
    angelito20 (26th November, 2022)
  21. #15
    Mar 2019
    Scandinavia
    Quote Originally Posted by flekken View Post
    Hi, is it possible to write injector codes with only ecu on the bench? Or does it need to be fitted in the car?
