Results 1 to 3 of 3
    Jul 2015
    Default BMW 750IL F01 . IAT AND MASS AIR FLOW PROBLEMS . ANYONE COULD DTC OFF??
    Hello chiptuners, need help if anybode could do this.
    I need remove the MASS AIRFLOW + IAT AND RELATED DTCS from this ECU.
    If anyone could remove at least the mass airflow only y whis try.
    COuld contact me by MP.
    Thanks in advance.
    Linked Ori ecu files:
    Meat-Head's Avatar
    Im not smart enough, can you look at fault code - often hexidemal and try wiping that libe in ecu?
    no need for private, dk sharing site
  3. The Following User Says Thank You to Meat-Head For This Useful Post:
    MadridEcu (18th September, 2020)
    Jul 2015
    Meat-Head . I tink was a bad cable because after swapping IAT and flowmass the -47 ºC persist and car not works fine again. After this we remove all cable between IAT and ECU , clean an reinstall and car works fine.
    Its important that all cable looks good but obviusly the porblem was there.
