Results 1 to 10 of 10
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    Default FIAT EVO 1.3 WITH START& STOP DOESN'T CHARGE THE BATTERY
    i have a problem with a Fiat evo 1.3 8f3 ecu with start and stop system, after an alternator replaced (original burned) with new quality one, it gives only 12 to 12,8 volts ....
    if i disconnect the cable from alternator that came from ecu it gives ~13,8v in ecu i have no error..... i had make dpf of the ecu, i put back original if the program makes the problem
    but not difference, still get 12v and some times 12,8.....
    what it could be the problem?
    Sep 2012
    portugal
    It's normal !
    It's a smart generator .
    Turn on all consumers ,lights , wipers and see if the volts go up
    If help press thanks
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    Quote Originally Posted by Tuiken View Post
    It's normal !
    i have doing that, if you have no consumption, the voltage is ~12 if turn the lights and clima on then it goes to 12,6 - 12,8 that's not normal, because the battery is empty....... (the battery is ok...)
    Jun 2017
    Did you eve sort this problem out ? I have the same the problem with fiat fiorino 1.3 multijet need help ??
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    Quote Originally Posted by erion97 View Post
    If I remember correctly the regulator was faulty...
  6. The Following 2 Users Say Thank You to Panathaole For This Useful Post:
    erion97 (16th February, 2023), mexanico1971 (26th May, 2024)
    Oct 2014
    PORTUGAL
    Hi ... I have the same problem on Punto Evo ECU 8f3. Put 3 alternators, last one original.. Any solution... Please.
    May 2024
    ANY SOLUTION?
    Dec 2022
    if no faulty altenator upload your ecu dump so as make appropriate changes and let again charge, because i have met situation with moded start stop off and no battery charge after that
  10. #9
    May 2024
    GEIA SAS PAIDIA BLEPO EIMASTE 3 ELLINES EDO.TELIKA POS LISATE TO PROBLIMA?
  11. #10
    May 2024
    HOW CAN I SOLVE THIS PROBLEM?
