Results 1 to 4 of 4
    May 2018
    Default Immo off Siemens EMS 3132
    Hello, i need to immo off this ecu ems3132 for a Nissan Platina HL 407 2004 , i read flash M29F200BB with ktag clone
    I hope you can help me with immo off.
    Best regards
    sergei5005's Avatar
    Nov 2012
    Bs As
    Default Try and report
    Hi friend . Here your original file edited OFF. Not tested . Try and report please. Remember cut inmo wire. In renault need cut pin 58 wire. but in nissan ???
  3. The Following User Says Thank You to sergei5005 For This Useful Post:
    IPrometheus (28th September, 2020)
    May 2018
    i will check the pinout, i will test and report how it goes. Thanks
    Best regards
  5. The Following User Says Thank You to IPrometheus For This Useful Post:
    sergei5005 (6th September, 2020)
  6. #4
    May 2018
    Hello i tested the file but it didn't work (i checked connection and pin 58 it's all right to that nissan), but actually it 's because the people who connect the ecu did it wrong and burned it .Now they brought to me another ecu (a sirius 32) that i'm trying to read with ktag (a sirius 32) but when i read it says "communication error" do you know why it's happening that ? i would like to do immo off to that ecu and get that car start. I cleaned the conections i use another wires and always says that (the ems3132 read very fast but sirius 32 it doesnt).
    Best regards
    and thanks again for the help with the ems3132.
