Hello guys
my problem is with already remap file but now i have some errors
P0400 - this is because the original map sensor does not respect the new pressure
Opel Astra - Y17DT DYRX ECU
Thanks for help![]()
Hello guys
test and report
egr dtc off
pass pm rep+thanks
stankadiew (6th September, 2020)
Hello mate.
The P0400 that turns on is because it detects an anomalous EGR flow (it reads it with the mass air flow sensor and compares it with the EGR activation percentage controlled by the control unit, in fact with the diagnostic you can see the desired values in command and those read). sometimes it is given even if you repeatedly press the brake 6-7 times quickly dissipating the depression of the circuit, for that I say that in 80% of cases it is a loss of depression from the sheath dresses. However, check that your intake manifold is not clogged too much and that the flaps move by moving the actuator by hand, and that you have no leaks from the intake / intercooler hoses.
freedoom (10th September, 2020)
Hi mate all ready of this is checked
I have cleaned the intake manifold and absolutely all turbo roads, intercooler and all vacuums
