Results 1 to 3 of 3
    Newbie Papaiamen's Avatar
    Aug 2019
    Gdansk
    Default Opel Meriva 1.3 CDTI, 2007 - Read/Write ECU with KESS V2.47 ECU 5.017 RED
    Hi guys
    i hope your week started in the best way.
    I own an Opel Meriva 1.3 cdti, 2007, and i have this interface KESS V2.47 ECU 5.017 RED
    which version of Ksuite you suggest to use for read and write custom firmware for improve performances of my car including consumes?
    i really appreciate your help
    Have a nice day guys
    Apr 2020
    I read kess v2 2.47 meriva delcoE87 1.7 cdti and it's ok. reads well and uploads
    Aug 2019
    Gdansk
    I was able to read ECU (attached files) by Ksuite tool and the kessv2
    https://easyupload.io/51a0qi
    that I bought to try to improve the performance of my car
    considering poor recovery and acceleration,fuel consumption, less power while using A/C
    My goal is:
    more power and torque, reduced fuel consumption, smoother acceleration and improved throttle response
    Also, I have the problem of the instrument cluster to be replaced (broken display)
    but despite having another one with the same code, once plugged, the car does not start.
    So I wonder if in the file just read, there is the possibility to remove this code so that I can replace it without problems instead of using the op-com or op-tech?
    can you help me?
    Thank you !
