[QUOTE=rob h;3950255]Write back the backup eeprom.
The org remote should then work.
Then program new keys. (if needed unlock and remake dealer key)
You should have added new key to dump, then write back, is my guess.
So unlock new key, ad to org dump, and write back dump.
And next time, start with old keys reprogramming before the new.
Or else they will be locked out.[
I did write the original eeprom that was that's what I was told to do from lonsdor I was adding a second key it does not have the options to add it direct to the eeprom original key was the first key that I program two the car would start on both keys afterwards walked away gone back to the car 5-minutes and the original key was not working but the remote was so then I proceeded to try second tools are you where I was now getting pin not recognised I know it was the original pin because I just programme the keys in 10 minutes before
I just thought he kicked the original key out because I been rushing I've done it too fast
This is your repaired eeprom dump file.
It may help you, but it's not 100 percent sure.
I am glad that I helped you.
coz1780 (20th September, 2020)
