Hi guys,
I need clear crash data
98820-7FM0A
XC2336B-40
Hi guys,
98820-7FM0A
XC2336B-40
here is your clear file
pass in PM
We make A
Living by
What we get,
but we make a
life by
What we give.
-Winston Churchill
jenya (9th September, 2020)
read full.
Flash0.bin
Flash1.bin
sistem.bin
ElderDM (5th September, 2022)
jenya (10th September, 2020)
Женя поділіться будьласка дампами 98820 7fm0a з крашем
Hello. Please help with cleaning the crash of this block. My cleaning option is the error code B1414
kaliso (28th November, 2020)
Thanks, I'll let you know on Monday.
Hello. Your solution does not work well, I still have the code B1414. It seems to me that this is an iprog solution. If I write it from this block 98820-7FL0C, then this error is not present, but this solution is bad because there will be errors on the shock sensor
what is dtc code B1414 more explain..........
This code stands for (control unit malfunction) it is generated when the crash is incorrectly closed, or if the control unit is faulty.
did you write your ori file and check it have B1414?
when I write ori file this error code I do not have.
