    Default NEED IMMO OFF EDC17 IVECO
    HELLO
    Some one can make immo off about ecu EDC17 IVECO 2019
    EDC17 0 280 030 088 5801593656 105046958 FPT
    Thank in advance
    best regard
    May 2020
    read ecu and post here
    hello
    i put the dump
    Hello, can someone check the checksum please. I did an immo off with immo17. Now on dashboard I have a message EDC PROBLEM and it does not start.
    Attached is the original and modified files.
    Thanks in advance
    rob h's Avatar
    May 2011
  5. The Following User Says Thank You to rob h For This Useful Post:
    newgeniehex (23rd September, 2020)
    Jun 2012
    Solution 0FF4 8020 8B02 2022 0090 does not work in all Daily after 2014.
    Iveco only.
    hello
    thank to all but the dump of ROB H is not work
    my friend have rocket dump ans the dump i same
    i think the solution is the emulator or the cheksum is bad?????
    what is the good emuator julie or other?
    thank in advance for answer
