Results 1 to 15 of 17
    May 2013
    Default please clear crash 9829442880 c3
    DeLuXe's Avatar
    Mar 2019
    Please attach a picture of srs module
    There should be a number starting with "A2C187"..
    Best regards,
    DeLuXe
    Sharing is carying. Please press Thanks + Rep Button if my post is helpful
    May 2013
    THANKS THIS
    May 2013
    THIS IS THE ECU
    DeLuXe's Avatar
    Mar 2019
    Your file cleared.
    Please give thanks, rep + comment and report file
    Pass in PM.
    Best regards,
    DeLuXe
  6. The Following 2 Users Say Thank You to DeLuXe For This Useful Post:
    i70ramih11 (13th September, 2020), occhiblu (16th September, 2020)
    Usa
    Default 9829442880
    Hi need help clear citroen C3 continental 9824809680 SPC560P50
    mobinec's Avatar
    Jul 2011
    your file tray and report
    Mar 2015
    Default please help to clear crash data!! 9829442880 a2c18747300
    please help to clear crash data 9829442880 a2c18747300
    Thank you!!
  10. #9
    VVlad's Avatar
    Ukraine Sumy
    This should work.
    Try and report the result
    Pass PM
  11. #10
    Sep 2018
    EU
    please, pass on pm - 100% work
  12. The Following User Says Thank You to kwat For This Useful Post:
    cunakis (11th March, 2022)
  13. #11
    Mar 2015
    Thank you, vvlad
    but file is the same, no changes in your file
  14. #12
    Mar 2015
    Quote Originally Posted by kwat View Post
    Thank you,
    in your file alot changes ,
    100 time more then in similar clear files!!
    will test it!!
    thank you!!
  15. #13
    VVlad's Avatar
    Ukraine Sumy
    изображение_2022-03-11_143332.jpgSorry, I didn’t finish watching my calc swears at your dump
    !!! If nothing has been written to the block yet, read it again. You misread the dump !!!
  16. #14
    Mar 2015
    VVlad
    this is i think bad dump,
    i try to read it several times and always is the same
    can you help me to fix it?
  17. #15
    VVlad's Avatar
    Ukraine Sumy
    According to the highlighted columns in your error dump. You need a dump with the same number, which will then need to be adapted to your block
