Results 1 to 8 of 8
    Apr 2019
    Default Astra H immo lamp blinking after key programming.
    Hello!
    Programmed a aftermarket remote key (from 3DGroup) today to a Opel Astra H 2005 in a AKL senario. AVDI put the new transponder in key memory place 3 and remote working fine. But car will not start. The yellow immo lamp is blinking. I get a fault code on wrong transponder signal.
    Any ideas are welcome!
    Dec 2018
    Did you make the battery off for a reset? My last 2 Astras H inhad to do it.
  3. The Following User Says Thank You to Alpaholic For This Useful Post:
    mjoesen (17th September, 2020)
    Apr 2019
    Quote Originally Posted by Alpaholic View Post
    Yes I did, but only for 1-2 minutes. How long did you take them off?
    ghostrider72's Avatar
    Jul 2012
    UK
    Reset takes 5sec. Can bad key in this case
  6. The Following User Says Thank You to ghostrider72 For This Useful Post:
    P&D's Avatar
    see if you can read the signal from the key
    if no signal
    check the coil is soldered proper
  8. #6
    Apr 2019
    Key read fine. Could it be a bad ignition coil if I manage to get the transponder in to key memory?
  9. #7
    Aug 2015
    if ignition coil is bad you could not program key in first place.... probably bad key....
  10. The Following User Says Thank You to dtip For This Useful Post:
  11. #8
    sdnatlst's Avatar
    Aug 2011
    England
    bad key or faulty CIM, quite common
    Tools owned -
  12. The Following User Says Thank You to sdnatlst For This Useful Post:
