Hybrid View
    May 2020
    Exclamation low boost? causes
    hello. i got a fault code P2263 which is "low boost" .
    i recently mapped my car and got the code after a month.
    can a pops and bangs cause this? or it's a mechinical issue like the wastegate actuator? thanks
    notice: the car boost is normal at highter rpms..only in low gears and rpms..
    Leeetoyo's Avatar
    Mar 2019
    Planet earth
    Were gonna need a bit more info on what make, model, engine type it is.
    If it’s twinturbo engine it could be small turbo or actuator giving up..
    Please don’t forget ‘thanks’ button if I helped!
    May 2020
    hi its a scirocco 1.4 twincharger
    May 2020
    Quote Originally Posted by Leeetoyo View Post
    hi its a 1.4 tsi twincharger engine which is turbo and supercharger
    Leeetoyo's Avatar
    Mar 2019
    Planet earth
    You could start by checking boost solenoid on top valve cover and all vacuum hoses that run across, also of valve between supercharger and turbo.
    Dont think supercharger can get damaged from Popandbangs
    May 2020
    didnt find any leaks or holes all fine. could it be the wastegate?
