Results 1 to 13 of 13
    Default FIAT 500 SIEMENS 5WK43908 AIRBAG
    Hello every body please have fiat 500 5WK43908 airbag
    51782985 have test with carprog not worked
    if some one can make good clear will be gratefull
    thanks a lot
    Croatia
    Hello
    This should work....
  3. The Following User Says Thank You to Mezz_cro For This Useful Post:
    motorsport (15th September, 2020)
    Dec 2019
    Melmak
    try it and report pls
  5. The Following User Says Thank You to shimekvrn For This Useful Post:
  6. #4
    Thank Lot does it already test solutions ?
    Croatia
    Quote Originally Posted by motorsport View Post
    My solution is tested by me....
  8. #6
    Quote Originally Posted by Mezz_cro View Post
    Hello have test have error internal
  9. #7
    Hello please hos repair error internal
  10. #8
    Jan 2017
    PL
    Test and Report
    Password PM
    No Report -> No Help
    "motorsport has exceeded their stored private messages quota and cannot accept further messages until they clear some space."
    If my post was helpful please push the Thanks button and Rep button.
  11. The Following 3 Users Say Thank You to dam234 For This Useful Post:
    alraracingautos (2nd November, 2020), motorsport (18th September, 2020), vadim bogat (19th September, 2020)
  12. #9
    Quote Originally Posted by dam234 View Post
    Test and Report
    Password PM
    Thanks can have clear my box
  13. #10
    Test and Report
    Password PM
    Still same error internal i think hardware problem not possible erase for ever this dtc ??
  14. #11
    Jan 2017
    PL
    Try this
    Same password
  15. The Following 2 Users Say Thank You to dam234 For This Useful Post:
    motorsport (19th September, 2020), vadim bogat (19th September, 2020)
  16. #12
    Try this
    Same password
    Thanks but same
  17. #13
    dragon100's Avatar
    Jan 2012
    From land of milk and honey
    Here tested 100% file worked on other cars, if not work then problem with hardware ...
    Best regards.
    Dragon
  18. The Following 5 Users Say Thank You to dragon100 For This Useful Post:
    alraracingautos (2nd November, 2020), christensen (6th July, 2022), mexanico1971 (24th August, 2022), mijatx (8th October, 2020), motorsport (20th September, 2020)
