Results 1 to 7 of 7
    jjservice's Avatar
    Sep 2016
    VIENA,AUSTRIA
    Default iPROG+ USB not RECOGNIZED
    Anyone had this problem of iprog+ USB NOT RECOGNIZED and show error message.... iprog+ Bought from AUTOSHOP,,
    Sent from my SM-J710GN using Tapatalk
    if you think i helped youkindly press REP+THANKS button
    Oct 2010
    Hello, I had issues with Iprog and the driver doesn’t work, at last I had to used a computer with system 32 bits.
    Are you using driver from folder or the system doesn’t recognized any new hardware
    Enviado desde mi iPhone utilizando Tapatalk
    autodiagservices's Avatar
    It’s not driver issue. It’s either the USB port of your laptop is bad or USB cable is bad. Try installing software on another laptop to reconfirm. Thanks
  4. The Following User Says Thank You to autodiagservices For This Useful Post:
    jjservice (17th September, 2020)
    jjservice's Avatar
    Sep 2016
    VIENA,AUSTRIA
    Hmmm... thanks alot on your advice.. i will try that...
    Apr 2019
    Hi, I have tried on win7 32bit and 64bit everything works
    Oct 2010
    Hello again, at least I had to install software on win xp 32 bits, on Windows 7 64 bits the soft doesn’t work for me
    jjservice's Avatar
    Sep 2016
    VIENA,AUSTRIA
    Quote Originally Posted by rybenz View Post
    It is working fine before,, couple of days i did not use it.. then 1 day came im in need to use it,, then USB NOT RECOGNIZED pop up..
