Results 16 to 30 of 36
  1. #16
    Junior Member AperoMyke's Avatar
    Sep 2020
    France
    Default Chrisimerk
    I am lost in view of the number of maps corrected for a stage 1 ....
    So I found 12 maps changed to be optimized.
    thank you for your information I continue to look for the% because I have no information on the number to change.
    thank you again friend !
  2. #17
    chrisimerk's Avatar
    Dec 2018
    England
    Quote Originally Posted by Antastra1989 View Post
    Chrisimerk cant send you private message inbox full
    Pm me now mate
    TUNING--FILE SERVICE--VMAX--EGR--DPF--FLAPS--LAMBDA--DTC--IMMO..........POSSIBILITIES ARE ENDLESS
    SPECIALISE IN TUNING DIESEL ENGINES
    (DEMON DEVELOPMENT)
    IF I HELPED YOU DONT FORGET TO HIT THANKS AND REP POSSIBILITIES ARE ENDLESS
  3. The Following User Says Thank You to chrisimerk For This Useful Post:
    Antastra1989 (20th September, 2020)
  4. #18
    chrisimerk's Avatar
    Dec 2018
    England
    Quote Originally Posted by AperoMyke View Post
    Use the map pack I provided it has all the necessary maps to change for stage 1 plus
    (DEMON DEVELOPMENT)
  5. The Following User Says Thank You to chrisimerk For This Useful Post:
    AperoMyke (20th September, 2020)
  6. #19
    Sep 2020
    France
    a first for me the insertion of map pack
    if I understood correctly here is the photo
    I still have found how to save it in .bin
  7. #20
    chrisimerk's Avatar
    Dec 2018
    England
    just click on import map pack then select the one i sent my map pack has way more maps then the one you have made
    regards
    (DEMON DEVELOPMENT)
  8. The Following User Says Thank You to chrisimerk For This Useful Post:
    AperoMyke (21st September, 2020)
  9. #21
    Sep 2020
    France
    Thank you
  10. #22
    Sep 2020
    France
  11. #23
    chrisimerk's Avatar
    Dec 2018
    England
    Here you go dyno tested stage 1 file use this or compare with your file this file is ok to write straight on
    regards
    pass in pm
    (DEMON DEVELOPMENT)
  12. The Following 2 Users Say Thank You to chrisimerk For This Useful Post:
    AperoMyke (23rd September, 2020), n0tiert (26th December, 2022)
  13. #24
    Sep 2020
    France
    I don't know how to thank you!
    I test it tomorrow noon directly
    and I'll get back to you
    cordially, Myke
  14. #25
    Sep 2020
    France
    Small return
    So with your carto: The car behaves like the original but with more cv. (lambda sensors behave normally)
    With mine: Completely different car, big thrust in 3/4/5 / 6th but nothing in 1 / 2nd speed.
    This is where I see that I am missing some settings to have something homogeneous to the original carto.
    Thank you for your help and for showing me the different maps on my Astra!
    Looking forward to read it again
    Sincerely, Myke
  15. #26
    chrisimerk's Avatar
    Dec 2018
    England
    Your map you are pushing too much boost more fuel hight torque curve if standard clutch won't last that long too much for standard car this is a safe map put the stage 3 if you want loads of gains but would not advise with standard car
    (DEMON DEVELOPMENT)
  16. #27
    Sep 2020
    France
    Hi, no, that suits me perfectly with your mapping.
    just the breaker has 8000 rpm
    this is the card for re at 6400 rpm?
    thank you
    Myke
  17. #28
    Sep 2020
    France
    Hi, how are you ?
    So if I understood correctly, you just changed the injector stop time to 65535.
    the breaker was still there
    on your file the downtime at 6080 was longer. (42598)
    Did I understand the principle correctly?
    Thank you
  18. #29
    Sep 2020
    France
    which brings me to
    a cold engine breaker at 32,500 rpm
    and at a temperature 90° of 6500 rpm
    is that possible?
    thank you
  19. #30
    Dec 2019
    UK
    Can someone look at my Stage 1 for my Astra H VXR?
    3rd gear boosts very well and then hit limp mode in 4th
    Toy'd with a few maps and haven't had a problem
    PS, sorry for hijacking. Just thought this post has people with knowledge of 7.6.2
    Eight bytes walk into a bar. The bartender asks, “Can I get you anything?”
    “Yes,” reply the bytes. “Make us a double.”
