Results 1 to 9 of 9
    Sep 2020
    Default Fiat Nav+ RRadio code
    Magneti Marelli C141
    IMEI:500189440048490
    735297003
    16ZC01B3C
    catalinosonesti's Avatar
    Mar 2019
    east nord pole
    Quote Originally Posted by RomanBusfy View Post
    735297003
    16ZC01B3C
    hi
    can you post dump from both Flash modules for code
    redrads
  3. The Following User Says Thank You to catalinosonesti For This Useful Post:
    RomanBusfy (16th September, 2020)
    Sep 2020
    what you meean by dump from both flash modules? how can i get it pls?
    Mar 2019
    east nord pole
    here my friend ,take a look it is no so hard
  6. The Following User Says Thank You to catalinosonesti For This Useful Post:
    Sep 2020
    Quote Originally Posted by catalinosonesti View Post
    it will be not that easy because i sold the radio today and the code i gave the guy is not working I'll write to him if he can check it somehow... It's impossible to get code without these numbers?
  8. #6
    Sep 2020
    Maybe one more info, when the ignition is turned off the radio is working like charm and there is no need to for master code, but when ignition is turned on it shows the master code request
  9. #7
    Sep 2020
    Posting dump from both flash modules please help
  10. #8
    Mar 2019
    east nord pole
    Yes
    That's it .
    You need to read it and post dump s here then get the code.
    Best Regards
  11. #9
    Sep 2020
    you mean like these numbers?
    29DL323TE-90PFTN 0142 M07U
    or how can i read the flash?
