Results 1 to 5 of 5
    May 2017
    Default VW Transporter T4 syncro
    Hi to all!
    I have a Vw T4 car with ACV diesel engine and electric fuel pump.Did someone knows if can i replace electric pump with mechanical pump?
    Thanks in advance!
    rafal's Avatar
    UK - PL
    no..........................
    need help
    now my goal is to buy xp-005
    who will help?
  3. The Following User Says Thank You to rafal For This Useful Post:
    georgedigital (21st September, 2020)
    May 2017
    Why not rafal?I know that electric pump have higher pressure to injectors than mechanical and the accelerator pedal are different.If I change pedal and remove immo it is not possible to work?
    kiszka's Avatar
    Quote Originally Posted by georgedigital View Post
    I think it should work without problems
    Reality of life :
    1:Never argue with an idiot, he will pull you down to his level and overcome you with experience
    2:Envy is the confession of inferiority
    3:Everyone lies
    How much trash you leave behind so much trash someone will have to read or maybe you yourself
    If you like reading garbage, don't slow down, just speed it up
  6. The Following User Says Thank You to kiszka For This Useful Post:
    May 2017
    I think so too...I may need to change the injectors too.
