Results 1 to 8 of 8
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    Default Renault Clio SIM32 Immo OFF
    hi...
    someone has a tested solution for immo oFF...?
    flash and eeprom are attached...
    Louislesinge's Avatar
    Jun 2017
    French Jungle
    Did never see Clio mark 1 (immo by wire) with SIM32, your Clio should be Clio II mark 2 with immo by CAN.
    If i'm right there is only emulator soluition with the new generation of pragrammable emulators.
    Tell us year or VIN of your Clio if you are not sure, please.
    Greetings,
    figani's Avatar
    Feb 2018
    VF1CB2U0541057429
    Jun 2017
    French Jungle
    Ok,
    This is mark 2 with immo by Can, so the cheapst way to start engine is to solve the problem. Report please what's wrong?
    figani's Avatar
    Feb 2018
    AKL....
    What kind of transponder can be used...?
    The blade we have...
    But electronic in key is lost...
    Jun 2017
    French Jungle
    Re,
    Have you Renault Clip? If yes it's easy and low cost to order new key and learn it to your car.
    figani's Avatar
    Feb 2018
    Have Renault ecu tool...
    Yesterday evening tried with new 7946...
    But get eveytime message, transponder wrong...
    Jun 2017
    French Jungle
    Ok,
    Change the ring. If done change UCH.
  9. The Following User Says Thank You to Louislesinge For This Useful Post:
    figani (18th September, 2020)
