Results 1 to 7 of 7
    Default edc17cp14 PIN CS MAC from dump
    Hello, I am trying to swap passat b6 ecu's. Can anybody could help extract pin mac and cs ? Even better make immo off.
    Attaching original and replacement Ecu's flash and eeprom.
    03L 907 309
    EDC17CP14
    0 281 015 029
    May 2017
    in fact of worse labeling i do in one eeprom... dont know which one old or new.
  3. The Following User Says Thank You to Lambda1 For This Useful Post:
    Coldas (18th September, 2020)
    same files with new labeling
    Quote Originally Posted by Lambda1 View Post
    sorry for bad labeling, i renamed files for better understanding. Immo off file works. Engine starts. But new ECU is with automatic transmision coded, and i get rejected when i am trying to change coding. Maybe you can extract pin codes from both ecu's ?
    Feb 2016
    old ecu pin 13532 cs 56AD7CF0AD5A00
    new ecu pin 00700 cs A3C7E1744E7500
    hackgsm's Avatar
    ORIGINAL
    ECU_MODEL=EDC17CP14
    VIN=WVWZZZ3CZ8E235894
    IMMO_ID=VWZCZ000000000
    CS=56AD7CF0AD5A00
    PIN=13532
    MAC=CCC66003
    hackgsm's Avatar
    DONOR
    ECU_MODEL=EDC17CP14
    VIN=WVWZZZ3CZAE207391
    CS=A3C7E1744E7500
    PIN=00700
    MAC=E916A099
  9. The Following User Says Thank You to hackgsm For This Useful Post:
    Coldas (24th September, 2020)
