Page 1 of 11 123456 ... LastLast
Results 1 to 15 of 161
    Default Vauxhall Corsa Blaupunkt CAR 2003 (F) code
    Can someone help me with the code for vauxhall corsa 2001 reg. Blaupunkt CAR 2003 (F) stereo key code. Details are as follows.
    SERIAL
    GM020317972399
    PART NO
    7649200321
    Thanks in advance.
    Moderator
    PremierD's Avatar
    Jun 2009
    Quote Originally Posted by nasir600 View Post
    SERIAL
    GM020317972399
    PART NO
    7649200321
    Thanks in advance.
    9511 mate ....... and you should introduce yourself before shouting for a code .......
    WOW. What a quick response. Sorry new to the forum. Stumbbled on DIGITAL-KAOS while looking for the code. Will try it and update on results.
    By the way.... are these key generators on torrents like radiodecoders.zip on public network any good. I tried one code generated from one of these and that did not work.
    What tools do you use to generate these codes from serials?
    Thanks Again.
    May 2009
    Thanks Again.
    This is a database already made....just put the serial and search and gives the code....
    Cheers
    MAXIMUS1000
    Moderator
    PremierD's Avatar
    Jun 2009
    Thanks Again.
    That's an easy one mate ...the correct one ...
    That code did the job.
    For the people who don't know the code insertion procedure.
    power off stereo.
    Turn the volume knob and "AS" button together (while the key is in ignition and in steering unlock position). Keep both button pressed until a beep is heard. After couple of seconds SAFE will change to a number and four "----".
    Use the numbers 1 to 4 to change the numbers. After setting the correct in the display press and hold "AS" until a beep is heard.
    I hope this helps someone.
    Where can I find the database? Is it in public domain?
    Jose19's Avatar
    From the HELL
    Is here.
    Use " Search bottun "
    Jose
    plz help i have Blaupunkt Opel Car2003F but i have unlock code...can u give it to me?thx a lot
    GM0203Y7444653
    7649200321
    Quote Originally Posted by bolik61 View Post
    GM0203Y7444653
    7649200321
    Here you are try it...
    First code: 2189
    Second code: 0189
    murat332's Avatar
    Türkiye
    Quote Originally Posted by Spaceboard View Post
    First code: 2189
    Second code: 0189
    not code error
    SAFE 10 - - - -
    SAFE 09 - - - -
    SAFE 08 * * * *
    Spaceboard **Post 1)
    bolik6**Post 1)
    MC68HC05B16 Read dump bin files here
    murat
    DK Veteran Badbad's Avatar
    GM0203Y7444653
    7649200321
    ***********1207**********
  13. #13
    Opel Car2003.rar
    this is my dump 24c01
    and why different forums give me different codes?which of them is right?orci can use all of them?
  14. #14
    Opel Car2003.rar
    hey try 1207 mate
  15. #15
    Moderator
    PremierD's Avatar
    Jun 2009
    Opel Car2003.rar
    Mate your original code ... based on your serials ... Is 1207 .... As posted above .....If you are getting the wrong codes ...given on other places ...... Don't go back there .....
