Hi.
RNS 510 1T0 035 680 C
HW: H06
SW: 2680
RNS 510 does not start. Black screen. Backlight is working. Current consumption 1.8A
CD drive does not work. Unable to enter into BOOT mode
I attach the screenshot: ST10F276, AM29F400, S29AL016, S29AL032, 24c32
Please help if someone has the working files
Thank you very much
Need only good dump for a S29AL016
seal777 (2nd October, 2020)
Anyone with dump for HW:H05 S29AL015?
Unit is dead, only LCD back light
Unfortunately not. The error was in ST10 and 29F400
I copied the ST10, 29F400, 24c64, S29AL016 from the identical radio and the radio started.
Unfortunately, I can not decode.
code from the radio from which I copied the files does not work on this radio.
code from the damaged radio also does not work.
Code Finder - Can't find the code
Does anyone know which flash contains the code and in which cells (would I replace the corresponding values from the corrupted files?)
HELP
hesham10 (1st March, 2021)
you need write new code.
Thanks for the offer Mikle1, i could try it. Anyway it can't get worse
My radio is with LCD, not sure if H11 is already with LED display?
Is there a site where you could upload it?
https://www.digital-kaos.co.uk/forum...ghlight=rns510
for found code you can use this app
can you share dumps that use for repair your unit
Hello again,
New patient. White screen, does not accept CD/DVD, reacts on power button + reset- and swl-mode button combinations with black screen. No communication with SetConfig.
S29AL016 copied from similar, working radio.
Any suggestions what to try next? Radio is 1T0035680B HW:H03.
