Results 1 to 7 of 7
Thread: Caddy Door Lock
    Rtronics's Avatar
    Dec 2009
    Australia
    Default Caddy Door Lock
    Hi, i need to dismantle this caddy door lock. it has damaged wafers inside. How do i take it apart. i want to remove cylinder and replace wafers.
    Failure is success, if we learn from it......
    Greetings from down under..... ( Australia )
    Feb 2013
    You have second pin
    Wysłane z mojego SM-G920F przy użyciu Tapatalka
  3. The Following User Says Thank You to swq123 For This Useful Post:
    Rtronics (19th September, 2020)
    Rtronics's Avatar
    Dec 2009
    Australia
    ok thanks.i removed pin but still barrel not come out. so if thats the 2nd pin where is the first
    tagirdn's Avatar
    Aug 2020
    UK Leicester
    There's only one pin. You need to remove the shank. It is held by a plastic ring inside . Before the anti-light mechanism. It comes out very tight. He once thought for a long time what and how.
  6. The Following User Says Thank You to tagirdn For This Useful Post:
    Rtronics (21st September, 2020)
  7. #5
    Rtronics's Avatar
    Dec 2009
    Australia
    i still cant work it out. im trying to lift this insert see pic but i dont want to break it.
  8. #6
    drupal's Avatar
    Jun 2020
    Hi, guys i repair this kind of lock in 2018 and i record pictures from my camera for someone need help.
    in this link you found location of pin i hope this pictures help all member
    https://mega.nz/folder/JMsTXDwA#DTQKIbQUdQJCHeG_f8KplQ
    use ctrl + to zoom in pictures.
  9. The Following 4 Users Say Thank You to drupal For This Useful Post:
    just4upal (22nd September, 2020), p1et (22nd September, 2020), Rtronics (21st September, 2020), triak88 (22nd September, 2020)
  10. #7
    Rtronics's Avatar
    Dec 2009
    Australia
    thank you.
