Best regards
Lots of people are having issues with the following DTC (P010129 - MAF Sensor 1, invalid signal received) on the E-Class W212 Delphi CRD3.5 (type 2). Often it turns out to be a leak from air intake pipe hose or a very dirty air filter, sometimes even dpf-related. But if, for any reason, the fault code can't be cleared after following all the official procedures, then is it possible to make a "DTC-off" solution? I've attached ori ecu dump. Thanks in advance for your help.
Best regards
2WD Dyno , Magpro2 X17, FLEX Master , KESS Master , AUTOTUNER Master, Byteshooter Master, EVC Winols Reseller
Official Magicmotorsport DistributorCode:FILESERVICE: Tuning / DPF / EGR / Adblue / DTC / Immo
Official Autotuner Distributor
Official Alientech Distributor
vdiag (21st September, 2020)
