Welcome to dk, your more chance if meeting Lord Lucan and Tupak at a Comet Xmas party
HI.
BSI
fuse A power assignment
F1 - - -
F2 7.5A - Diagnostic socket
F3 3A - anti-theft ignition switch - engine start switch
F4 5A - separate telematics module - stolen vehicle location module
F5 3A - tire low pressure detection system calculator
F6 15A - Radio
F7 15A - fuse box inside the vehicle
F8 3A - anti-theft alarm volumetric protection module - anti-theft alarm siren - ADML electronic key reader
F9 3A - Switch module under the steering wheel (COM2000)
F10 - - -
F11 5A - stability control calculator
F12 15A - dual-function brake contactor
F13 10A - FRONT LIGHTER
F15 - - -
F16 3A - glove box lighting - left rear reader
F17 3A - central front ceiling lamp
F18 - - -
F19 5A - Instrument cluster
F21 10A - air conditioning calculator - multifunction front panel - driver seat memory module
F22 5A - multifunction screen - dot matrix display on the instrument cluster - parking assist calculator
F23 5A - control board-fuse box in the engine compartment
F24 3A - rain / illumination sensor
F25 5A - airbag and pretensioner module
F26 15A - -
F27 3A - gear selector
F28 15A - Radio
F29 3A - -
F31 30A - lock assembly
F32 10A - audio amplifier
F33 3A - -
F34 5A - telematics receiver control - module for displaying information in the field of view of the road
F36 - - -
F37 3A - Headlamp corrector switch
F14 10A - 12 V socket
F35 3A - power steering relay
F39 30A - lock assembly
F30 20A -
F20 5A - smart beam
F38 3A - electrochromic interior rear-view mirror
PSF1 BSM
F1 (MFRM) 5A - piloted air inlet module
F5 (MFRM) 5A - anti-lock steering wheel angle sensor
F8 (MFRM) - - -
F9 (MFRM) - - -
F10 (MFRM) 5A - automatic transaxle control unit - automatic transaxle grille position
F12 (MFRM) 15A - gearbox ECU AM6 / AT6 - manual gearbox ECU solenoid valve
F13 (MFRM) 20A - heater (cab fluid heating)
F14 (MFRM) - - -
F15 (MFRM) - - -
F19 (MFRM) 10A - heater water pump relay
F17 (MFRM) - - -
F18 (MFRM) 5A - additional double function stop contact
F11 (MFRM) 5A - brake calculator
F6 (MFRM) 40A - Front right and front left windshield wiper motor
F1 15A - Main Relay protection BPGA - engine control calculator
F16 (MFRM) 5A - Vacuum pump-heater water pump relay
F25 30A -
F2 5A - engine cooling
F3 5A - engine ECU calculator
F4 5A - central voltage support system
F5 15A - engine ECU calculator
F6 20A - engine management ECU - pump / fuel gauge
F11 15A - Headlamps - dynamic correction module for headlamps
F8 10A - fuel additive pump - engine ECU check
F13 5A - Drive mode selector - power electrical module and control unit
F15 5A - power steering electropump assembly - cabin air heating resistance - heater water pump relay
F12 5A - ABS calculator - stolen vehicle location module - compressor control relay for the cold generation system
F16 20A -
F18 - - -
F20 15A - Windshield washer pump
F21 20A - Headlight washer pump
F22 15A - horn
F23 15A - right headlights
F24 15A - left headlights
F27 5A - left headlights
F28 5A - right headlights
F30 30A - engine ECU calculator
F9 10A - electric steering lock
F17 10A - Intelligent Control Module (BSI)
F29 30A - starter
F10 5A - Diagnostic socket
F7 10A - Engine calculator - water diesel fuel
F26 10A - air conditioning compressor
F19 - -
F14 25A - screen washer pump earth
BGPA Acumulator fuse
F1 80A - fuse box inside the vehicle
F20 - - -
F2 70A - BSI (intelligent control module)
F3 125A - control board - fuse box in the PSF1 engine compartment
F4 60A - BSI (intelligent control module)
F5 60A - electronic module for controlling the radiator fan group
F6 - - -
F7 40A - anti-lock brake system - stability control
F8 20A - anti-lock brake system - stability control
F9 60A - fuse box inside the vehicle
F10 40A - blower control module
F11 40A - fuse box inside the vehicle
F12 80A - heating resistance of the cabin area
F13 70A - heating-reheating controller
F14 40A - electric parking brake
F15 80A - Power steering
F16 30A - Controlled manual gearbox calculator
F17 40A - central voltage support system
F18 - - -
F21 5A - battery charge status module
F19 40A - Cab fuse box (BFH5
BR
