Results 1 to 13 of 13
    Dec 2015
    Portugal
    Default Peugeot 206 K-line Remote not programming
    Customer just have 1 transponder key.
    Try to program a remote to a Peugeot 206, but don't succed.
    Program transponder, but remote don't work.
    Without fog lights, trying to program a 6554YL remote. (Already try KD and Original).
    Could read BSI without DTC
    BSI Identification
    Functional Plan No: 9649627880
    Manufacturer: Siemens
    Functional Product: 9649627880
    Software Index: 04.00
    Serial Number: FFFFFF
    Manufacturing Date: 255/255/2255
    System: B1
    Software edition: 34.11
    Software signature: 93.37
    Software reference: 9656355580
    Programming Date: 31/1/2005
    Reprogramming counter: 2
    VIN: VF32AHEXF42856650
    Engine type: TUIJP (1.1 i)
    Check fuses, and all OK.
    There is a receiver or antenna to check?
    Or what to check now?
    Thanks in advance.
    Tools: AVDI, Im608, VVDI 2, VVDI MB, T-Code, SBB
    Eeprom: VVDI Prog, Orange, Tango, TMPro, R270, ABPROG
    Other: VVDI Mini Key Tool, Key Tool, KD-X2
    Electronic key machine: Silca Triax, Idea, Unocode
    rob h's Avatar
    May 2011
    The transponder and remote pcb are matched.
    Programming the transponder, will allow the remote to work.
    If you swap the trasnponder, the remote wont work.
    I read somewhere on D.K. that a used transponder can be reporgrammed.
    And you can always created a remotekey, using keydiy or Xhorse
    RIMKACHIP's Avatar
    Feb 2012
    Pcf7936 is paired with remote Green card. If you have new pcf7936 and you want to match original remote or remote of another 206 it’s not possible. If you want remote work you must add new original key (pcf7936 Virgin with remote card of this Virgin pcf7936) or new chinese key pcf7961 with antenna on remote and not have pcf7936 on key.
    Envoyé de mon iPhone en utilisant Tapatalk
    szengen's Avatar
    Jan 2017
    Default try
    Quote Originally Posted by rob h View Post
    .....ok206.rar
    https://www.youtube.com/watch?v=GceZ9uyOQSM
    fang, Narwalus microcephalus,Spectrum Zx, Atari amiga, Commodore +4
    szengen's Avatar
    Jan 2017
    from the red lights in the city to the next lights in the city I don't see a faster car
    Dec 2015
    Portugal
    I know that.
    I didn't swapped anything.
    Remote was virgin.
    The problem must be in the car. I just don't know what to look or test.
    RIMKACHIP's Avatar
    Feb 2012
    Quote Originally Posted by lmqcatarino View Post
    I know that.
    Remote was virgin.
    What is your Virgin key ? Chinese or original with 7936 ?
    swingman26's Avatar
    france 26
    BSI Identification
    System: B1
    Thanks in advance.
    On this car with chinese remote, you must use pp2000 and enter to bsi and change configuration on RF receiver. Put new RF receiver with frog light.
  9. The Following User Says Thank You to swingman26 For This Useful Post:
    lmqcatarino (23rd September, 2020)
  10. #9
    RIMKACHIP's Avatar
    Feb 2012
    Quote Originally Posted by swingman26 View Post
    Yes if chinese remote you must change type rf you have 4 types.
  11. #10
    RIMKACHIP's Avatar
    Feb 2012
    If you have original key and good reference of key. You can change com2000 because antenna of rf is inside com2000.
  12. The Following User Says Thank You to RIMKACHIP For This Useful Post:
  13. #11
    Dec 2015
    Portugal
    Quote Originally Posted by RIMKACHIP View Post
    There is no way to test that antenna before change?
    It's possible problem is BSI, right?
  14. #12
    Dec 2015
    Portugal
    Pp2000 it's lexia, rigth?
    I don't have it.
    Some suggestion trust place to buy?
    Or could I make that change configuration on BSI with other tool?
  15. #13
    RIMKACHIP's Avatar
    Feb 2012
    You can use autel for testing réception of rf signal or for change type of signal remote.
