    rob h's Avatar
    May 2011
    Default Polo Simos 9.1 dtc
    Could someoen help me out here,
    03D906023
    simos 9.1
    DTCS
    16804 P0420
    18528 P0171
    Could someone remove these 2 dtcs?
    9.1 03D906023.rar
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    Quote Originally Posted by rob h View Post
    03D906023
    simos 9.1
    DTCS
    16804 P0420
    18528 P0171
    9.1 03D906023.rar
    try it...........
  3. The Following User Says Thank You to figani For This Useful Post:
    rob h (24th September, 2020)
    I wouldn't remove P0171. That's a sign that there's something wrong with the fuel mixture (way too lean).
    When you continue driving with this fault you can also burn the valves and then it will be an expensive repair.
    The other dtc (P0420) could be the result of the P0171 fault and the cat may not be damaged (yet).
  5. The Following 2 Users Say Thank You to oldford For This Useful Post:
    bobolin4o (25th September, 2020), rob h (24th September, 2020)
  6. #4
    rob h's Avatar
    May 2011
    I have had a chat with the mechanic.
    I told him, to get another ecu, to test.
    He is convinced that the wiring is fine, and replaced the sensors twice.
    This afternoon, i will clone the immo. And go from there.
    Thank you guys
    Which sensors did your mechanic replace? The Oxygen sensors?
  8. The Following User Says Thank You to oldford For This Useful Post:
    rob h (25th September, 2020)
  9. #6
    rob h's Avatar
    May 2011
    i dont know, customer needed the car, for a holiday trip.
    I will know more, when he returns.
    I did take the time to clone the eeprom, on a 03D906023B from a Fox.
    The values and dtc are the same. So we can rule out the ecu itself.
