any help with this one please guys ?
Hi everyone
i hope everyone is well today ...
please can someone help me to get a pin code for Citroen c2 from bsi. i need to add key but abrites unable to connect.
ive used UPA to read info hc9s12dp512
bsi info: Valeo
96 592 854 80
bsi 2004 p07-00
07-07-2006
control 3
any help would be much appreciated
kind regrads
c
if it valeo bsi i think need to read 95128 can check it again, and post photos of bsi
Charlieb1 (24th September, 2020)
yes................inside is 95128....................
need help
now my goal is to buy xp-005
who will help?
hmmmmm.... i am pretty sure that data in bsi is stored in eprom 95128
hi guys , thank you for the reply .this bsi is sealed (no chips on the outside and its soldered together so i cant get to the eeprom . ive used the points at the back of the bsi to read the info via upa . can you maybe provide me with a pinout or something .do you need a pic of the sticker on the bsi or a pic of the full bsi as i still have it attched to upa .
pictures of bsi
guys am i reading the information wrong?
desolder or cut side pins, remove one pcb from other
check this, i think this will work on your pcb
rafal (24th September, 2020)
