Results 1 to 7 of 7
    Mar 2020
    Default BMW E81 118D EDC17C06 LITTLE HELP NEEDED
    Hi.
    I am trying to increase the power in my car. My goal is 380-400NM.
    I changed all the torque limits and some boost maps but still can't go over the factory 300NM.
    After removing the DPF filter, I reached my maximum of 313NM
    Could someone view my file and tell me what I missed?
    Northern europe
    Try this version.
    Pass in PM
  3. The Following 2 Users Say Thank You to jaxone For This Useful Post:
    marko6jpt (25th September, 2020), Widurr666 (25th September, 2020)
    Mar 2020
    Thanks. I will check and compare both files. If I find the answer, I will let you know, maybe it will help someone.
    Mar 2020
    Ok, car work perfect. I use kess bootloader to upload file. Thanks for help.
    Oct 2019
    i even put them up to 500nm
    Mar 2020
    My next stage will be a replacement for injectors from the f10 / 11 184KM version and a hybrid turbocharger.
    Mar 2020
    I have one more question. What about the fuel system when replacing the 123d / 125d injectors?
    Will my high pressure fuel pump maintain the recommended 2000bar?
    Should I replace the pump and the injection rail with the one from 123d?
