Results 1 to 4 of 4
Hybrid View
    Aug 2015
    Spain
    Default Volvo V50 sync CEM and EDC16C34
    Hi guys, I have again a Volvo V50 to synchronize the data of the ECU EDC16C34 (95160) and the MODULE CEM (0L01Y).
    The ABS ID is 000000013770.
    Adjunct Eeprom of the ECU or the EMU module.
    Thanks a lot.
    Aug 2015
    Spain
    Anybody help?
    Aug 2015
    Spain
    Doesn't anyone know the solution to this problem?
    Aug 2015
    Spain
    Kizka is right, the problem is not in sync, because the ECU eeprom file is fine. The problem is that the car left the keys on with the contact on and when you started it the car does not move the starter engine and there are failures in the ABS that there are communication problems with the ECU and that no initialization check has been performed.
  5. The Following User Says Thank You to Josue For This Useful Post:
    kiszka (29th September, 2020)
