Results 1 to 14 of 14
    motocarlos's Avatar
    Jun 2009
    Portugal
    Default need help with good file transit connect 2T1T 14B321 AC
    Hello,
    a have a Transit Connect from 2007 with an front crash and driver airbag and passenger side pretensioner open.
    Now the new driver airbag is on place, but i wait for the belt pretensioner passenger to install,
    but stored on the ecu crash in memory and i need to make the car run again.
    I need help to check if the files upload here is good or not, or some good dump for this ecu.
    Ecu: 2T1T 14B321 AC 0285001955
    Regards.
    WORK WITH KWP 2000+, GALLETO 1260, BDM 100, FLASTEC CLONE WITH MAGPRO2, VAGCOM, FIAT ECUSCAN,UPA USB, MAXIDIAG, TOP 2049, PROG EXPRESS, AND MORE....
    Sep 2020
    Hello there are two files inside zip, try both....
    pass in PM
    report and thanks
  3. The Following User Says Thank You to alby01 For This Useful Post:
    motocarlos (27th September, 2020)
    motocarlos's Avatar
    Jun 2009
    Portugal
    Quote Originally Posted by alby01 View Post
    pass in PM
    report and thanks
    Hello,
    what is the good file you send??
    Regards.
    Apr 2020
    Akkerman Odessa
    Default clear ford transit conekt
    clear plis
  6. The Following User Says Thank You to vadim bogat For This Useful Post:
  7. #5
    Sep 2020
    try both, there are two files cleared with different tools
  8. The Following User Says Thank You to alby01 For This Useful Post:
  9. #6
    motocarlos's Avatar
    Jun 2009
    Portugal
    Tkx, i will try it and report back.
    Regards.
    Enviado do meu SM-A405FN através do Tapatalk
  10. #7
    motocarlos's Avatar
    Jun 2009
    Portugal
    Hello,
    The crash file is ok car run again but now always error from airbag passenger side but this car dont have it.
    Another file good?
    Regards.
  11. #8
    May 2017
    Turkey
    test and report
  12. The Following User Says Thank You to hasankrgc For This Useful Post:
    motocarlos (29th September, 2020)
  13. #9
    Jul 2020
    is the vehicle from USA market?
    I usually buy from tachosoft or carprog
  14. #10
    motocarlos's Avatar
    Jun 2009
    Portugal
    Quote Originally Posted by Alex77ae View Post
    Hello,
    the car is not from USA, its from Portugal.
    Regards.
  15. #11
    motocarlos's Avatar
    Jun 2009
    Portugal
    Quote Originally Posted by hasankrgc View Post
    test and report
    Hello,
    Regards.
  16. #12
    motocarlos's Avatar
    Jun 2009
    Portugal
    test and report
    Hello,
    Not work too, error passenger side and the car doesnt have airbag passenger side, any other solution?
    Regards.
  17. #13
    dragon100's Avatar
    Jan 2012
    From land of milk and honey
    I think you can use elmconfig soft with cable elm327 or els327 and change configuration ...
    Scripts for Multi-PROG
    You use srs units files at your own risk. I am not responsible for any damages. Don't ask about passes, one file=one pass.
    If I helped, please, use magic buttons reputation+thanks.
    Best regards.
    Dragon
  18. The Following User Says Thank You to dragon100 For This Useful Post:
    motocarlos (1st October, 2020)
  19. #14
    motocarlos's Avatar
    Jun 2009
    Portugal
    Quote Originally Posted by dragon100 View Post
    Hello,
    i have buy a used ecu, i will try it on the car.
    Regards.
