Results 1 to 4 of 4
    Aug 2020
    South Africa
    Default Opel 1.7 dti corsa c
    Hi guys, need some help on a opel corsa c 1.7dti 2006, the vehicle, just cut out. And the only lights on the dash is engine management, handbrake and battery. No glow, oil, spanner light. I have two diagnostics systems, both does not pick up the ecu, checked all fuses.
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    Quote Originally Posted by RUSSEL007 View Post
    check your grounds, and cables...
    Aug 2020
    South Africa
    Ok so i found the problem, it was the ecu. Changed it, recorded. And its back online ����, stil need to sort out the speedometer thats not picking speed up
    Aug 2020
    South Africa
    Thanks, i checked it all
