Results 1 to 14 of 14
    Default Renault clio 7 648 027 391
    hi.need help with renault clio blaupunkt 7 648 027 391 eprom m95256w which is locked.I have code 7907.Thanks for any help.
    Albert G's Avatar
    Apr 2016
    Quote Originally Posted by mickko View Post
    Send us the serial number BP8027xxxxxxxx
    Or on another label stuck on the radio the pre-code
    Example:
    28 115 0040R T A216
  3. The Following 2 Users Say Thank You to Albert G For This Useful Post:
    Decode Ghost (29th September, 2020), jeank (30th September, 2020)
    I have code but unit is locked and i just need timer reset.Thanks
    Anybody with help please.
    smoggy's Avatar
    Apr 2009
    UK North East
    I'm not too sure
    Nov 2013
    Macedonia
    File in post #1 is bad read.
  8. The Following User Says Thank You to Zann For This Useful Post:
    shooting (30th September, 2020)
  9. #7
    Default Renault Clio timer reset
    i have read the dump again.I need timer reset.Thanks
  10. #8
    Nov 2013
    Macedonia
    Files in post #1 and post #7 are identical, both are bad.
    Maybe there is some bad contact, maybe eeprom is damaged.
    If you reading with clip, try to desolder eeprom from board and read directly.
  11. The Following 2 Users Say Thank You to Zann For This Useful Post:
    REZON (30th September, 2020), shooting (30th September, 2020)
  12. #9
    Hi Zann.I read eprom again with a different programmer.The eprom is a m95256w but the other programmer has only m95128w listed.It did read most of it.One quick question ,what part of dump is corrupt.Thanks.
  13. #10
    Nov 2013
    Macedonia
    It has too many errors. One of them is this. At address 4E6h there should be text /T23J
    Is radio working? What is on the display?
  14. The Following User Says Thank You to Zann For This Useful Post:
    shooting (1st October, 2020)
  15. #11
    It just says wait i have been told
  16. #12
    Nov 2013
    Macedonia
    If you know correct code, it is better to wait 1 hour, with ignition to ON and then enter the code.
    If you try to write different data to eeprom, there is big risk that radio will never start.
  17. The Following 2 Users Say Thank You to Zann For This Useful Post:
    mickko (1st October, 2020), shooting (1st October, 2020)
  18. #13
    carradio2001's Avatar
    France
    Are you sure you read the eeprom from RADIO unit ? Not navi, not CD, not any !
    Carradio2001.
  19. The Following User Says Thank You to carradio2001 For This Useful Post:
  20. #14
    KierAn20's Avatar
    UK
    This dump is fine and normal but you need to read nec to get the values to know how many steps back the counter needs resetting mate.
  21. The Following User Says Thank You to KierAn20 For This Useful Post:
