Results 1 to 9 of 9
    Aug 2018
    Default Honda 2.2 ictdi BDM read Test ECU ID number, could it be?
    Hi guys,
    I would like to made an Accord 2.2ictdi EGR OFF
    Car is 2004 With EDC16C1-7
    Ktag didn't show ID datas but the files flash/mpc/e2prom seems okay. Winols see edc16 checksum blocks
    When I see the file there isn't a Bosch Sw number attached picture about it.
    There is TEST00643P290 instead 1037xxxxxx Bosch Number
    Is there anybody who can confirm this could be working if I write it by BDM flash for EGR off.
    I readed with FGtech Galletto V54 the flash to compare it read the same as KTAG
    Thank you
    Aug 2016
    I know that wotek is old but I have the same reading.
    My problem is that the car has no errors and from time to time goes out. Sometimes ride a week normally. The next day it does not fire.
    Just remove the error and the car fires. Although and does not show. I prubowałem various testers and none shows anything.
    The pressure on the injection strip is also 30 mp
    Could this be a problem
    Jan 2020
    Bulgaria
    Galleto V54 does not count chks....
  4. The Following User Says Thank You to vnkto For This Useful Post:
    lukasz12345 (6th May, 2022)
    Apr 2022
    i have experience with this cars ... i have 2 of them ... i just want you to know this car does not like the egr off ... you will loose power you better leave it on
  6. The Following User Says Thank You to selveti2022 For This Useful Post:
  7. #5
    Aug 2018
    Quote Originally Posted by selveti2022 View Post
    No problem with egr off.
    Just should 0ed the 2 needed EGR Hysterisis curve.
    If has a power loss maybe the egr stuck in open position.
    Than blank it with metal plate than will be okay. Not need to unplug the connector of EGR. Hope it helps
  8. The Following User Says Thank You to user202 For This Useful Post:
  9. #6
    Aug 2016
    My problem is the car doesn't start sometimes.No errors Fuel pressure approx.Wires cubes checked.
  10. #7
    Apr 2022
    hotstart problems you have ....hotstart map needs to be adjusted .... if you have problem only in cold ...there is also cold start map
  11. The Following User Says Thank You to selveti2022 For This Useful Post:
    lukasz12345 (7th May, 2022)
  12. #8
    Aug 2016
    where are those winter and hot maps.can you do for me my org file is above
  13. #9
    Aug 2018
    This is not VAG car, where this cold and hot starter maps definied differently. It has only one starter map.
    The problem can be electronically from ECU, I advice to upload again unmodified original ECU file and see what's happened.
    If there are also the starting problem I think you should take a deeper look on your engine and supplier components like Rail, Injectors etc...
    If anyhow need my help to adjust the starter map find in attachment
    (checksum calc by Kess during the writing)
  14. The Following User Says Thank You to user202 For This Useful Post:
    lukasz12345 (11th May, 2022)
