did you try battery off for a while ?
Hi all, used the X300 DP today on a 2012 Fiat 500 to program a spare plain key.
All went well, precoded the plain ID46 key (PCF7936) with no problems and then programmed the original remote key and new key to the car.
Both keys will now start the car but the original fob key will no longer operate the locking on the car.
Is there a prcedure I need to use with the x300 to get the remote locking working again please anyone ?
Thankyou in adance for anyone who knows the solution
CODEREADER (1st October, 2020)
Hi. There was an error in adding a key, you finished the process without saying the procedure was successful. solution replace the remote key chip 7946. and precode the vehicle and add 2 keys.
Dont know about fiat 500 but on fiat stilo after key programming there is procedure also for remote key programming/sync, remote key programming needs also pin code.
I assume on fiat 500 is same procedure.
Btw. Original remote key you can sync anytime again, about the spare key if it starts the car i assume you dont need to replace pcf just sync remote
Poslano sa mog SM-G975F koristeći Tapatalk
No did not try battery diconnection, will try when the car comes back
Thanks , I was thinking maybe I will have to replace the pcf and precode the fob again.
Will order in a chip and try again if needed.
Hi, i have re-programmed the original key again but this did not bring back the remote locking.
X300 has the menu options 1. program key 2. Program remote, I did try the program remote option and entered the pin but the process does not complete just tells me to make sure key is on etc.
The car is coming back to me soon and I will try again
When you programm the remote with the pin it should tell you to press on remote any button and after that on diagnostic device it should show up remote id, that means remote is programmed.
i had on fiat stilo issue with autel on remote programm it has not work, old sbb has then programmed remote succesfull
If the key is running the vehicle, the insertion is successful, check the remote board frequency.
CODEREADER (1st October, 2020), musti418 (1st October, 2020)
I do not want to debate with you if it is bullshit or not but fiat stilo and fiat 500 has same procedure for sync remote - pin code required!
he should be able to sync old fob anytime if tool is capable of programming remote, i know for sync remote i had to use old sbb instead of autel.
Just wanted with him to share my experience
Btw. On fiat stilo there is also no seperate function to programm remote it has to be done in the key programming procedure.
lion0304 (2nd October, 2020)
I dont write in every post rep + thnx like many of you
And i was inactive here last 5 years, the forum database moved and there is where my thnx has lost but i dont look about this, check out my old posts and see how many i contributed here from beginning.
and pls i didnt really ask you anything so dont know why you quote me at all
mind your own business if you have any
