Results 1 to 3 of 3
    Sep 2018
    USA
    Default 2019 Sonata Hybrid incorrect file size?
    Hello, made the mistake of trying to reprogram mileage for this 2019 mb91f061bs sonata hybrid cluster through the obd in vehicle, on the "patch flash" it went dark. I have the file attached here. The problem I am having is the cluster is not powering up. On the bench I can still read the eeprom and edit the mileage but still can not power up. When I try and write original flash file back into the cluster on bench it says my flash size needs to be 576KB but mine is 544KB so it will not let me flash/write it. Maybe someone can help change my file size to 576KB? Or if anyone has a dump for this car that would be amazing. I have dsp3+, sf/s tool to use.
    mislav88's Avatar
    Mar 2011
    read dash with programmer and post here also corrupt dump
    Sep 2018
    USA
    Quote Originally Posted by mislav88 View Post
    Not sure if this is what was requested but here is the dash eeprom file...
