Results 1 to 7 of 7
    Sep 2020
    Default crafter kess wrong security code
    VW crafter with ecu edc16cp34 - kess unable to communicate with ecu, "wrong security code".
    Have been told to leave the ignition on for 30 mins and it will allow access.
    Any one know if this would work?
    Senior Member smotorsport's Avatar
    Feb 2018
    In most cases it would, if not best way is to read with ktag on bench.
    Dec 2019
    UK
    Quote Originally Posted by neilmch View Post
    Neil, try KLINE
    Eight bytes walk into a bar. The bartender asks, “Can I get you anything?”
    “Yes,” reply the bytes. “Make us a double.”
    Sep 2020
    Just been told that every error it gives it adds 30 mins, so 4 failed logins it will need to be left with ignition on for 2 hours......that means i need to leave the ignition on for a few days to be certain
    Peechie mate, you know where i am at now, Right back where i started after first writing to the ecu, turns out that ori file thats has been corrected and back on is the one with the dodgy egr+dpf deleted and no speed limiter
    Edited to add: just found this thread on the forum, crafter aswell - https://www.digital-kaos.co.uk/forum...+security+code
    Oct 2019
    it has rolling code. must always use and mod last file that started car!
    Sep 2020
    can not even id, or read ecu as same error
    May 2019
    Only BDM ! (Ktag)
    For some days i have the same Problem! after 50 % Write the Brake up write. With MPPS and kess .
    For 1 Year a friend have Flash same car with CMD and they brake up obd write too. I dont now whats Wrong with this shit ECU.
