Results 1 to 2 of 2
    Smile 2017 Suzuki Vitara 1.4 Booster Jet Manual/wiring digram required
    Hi guys currently have fairly bad running problems with Boosterjet 1.4 suzuki, seems to be hunting when hot with what seems a lean missfire, fuel trims within 10% no obvious eobd faults except for odd cam sensor fault, cam sensor replaced but fault still came back once and dont see any change in cam angle pid, stuck at 0 degrees, could really do with more info on this one but none seems to be available. would appreciate any info or wiring diagrams for the Engine especially,
    did scope cam sensor and signal seems fine.
    any help appreciated
    brownbajan's Avatar
    Feb 2009
    the islands
    check this
