i have same error could you fix it?
Hello there ,need help with MIB STD2 PQ +nav SW0363 HW31 ,i got it with bootloop VW Logo ,im try flash it in emergency mode ,but still again bootloop with logo ,attached part of log from PuTTY:
-Welcome to TechniBoot-
SVN Rev: 579332
J5e.M30.LoadImage.ready: 0x0422E139
J5e.M31.LoadImage.ready: 0x04FF54F1
J5e.QNX.LoadImage.ready: 0x1E8044EE
CPU0: L1 Icache: 512x64
CPU0: L1 Dcache: 512x64 WB
CPU0: L2 Dcache: 4096x64 WB
CPU0: VFP-d32 FPSID=410330c3
CPU0: NEON MVFR0=11110222 MVFR1=00011111
CPU0: 413fc082: Cortex A8 rev 2 600MHz NOALIGN
Loading IFS...done
System page at phys:840f4000 user:fc404000 kern:fc404000
Starting next program at vfe051524
cpu_startnext: cpu0 -> fe051524
VFPv3: fpsid=410330c3
coproc_attach(10): replacing fe081910 with fe0810cc
coproc_attach(11): replacing fe081910 with fe0810cc
Welcome to QNX Neutrino on the Texas Instruments J5 ECO MIBSTD2NAV_MAIN Board (ARMv7 Cortex-A8 Core)
Thu Jan 01 00:01:00 UTC 1970
add net default: gateway 10.200.1.2
J5e.QNX.init.ready
Waiting for i.MX...
Unable to access /net/imx6/tmp/main-startup-no
Current core file directory: /tmp
abcdefghijklmnopqr>ABCDEFCC:0x00000000
SC:0x00000000
HC: 0x00000000
GH>s>J5e.imx6.start: 0x01D32AC9
try to update firmware via emergency mode
Hello I have the same problem, MIB STD2 PQ + NAV SW 0359 HW H 31 5C0035680D VW AMAROK 2017, any solution?
Contact you seller software for support is easy
Sir how to put unit emergency mode?
angmar (20th May, 2021), audiopoint (9th June, 2022), catalinosonesti (23rd May, 2021)
angmar (20th May, 2021), catalinosonesti (23rd May, 2021)
https://drive.google.com/file/d/1odJ...ew?usp=sharing
use this instruction
angmar (3rd January, 2022), catalinosonesti (23rd May, 2021), SasaZg (31st January, 2022)
hello , please help me. I have mib std2 pq plus , problem - bootloop on logo after try to backup emmc . Have log from imx6 serial:
SVN Rev: 650763 - Nov 21 2017 / 22:49:12
Variant: PQ stdPlus sop4 1GB LPDDR3
CAAM: CAAM_CSTA 0x00000202 - trusted Mode
CAAM: init -> ok
CAAM: open already instantiation ring 0!
CAAM: open ok
Image verified
CAAM: clock 0x00018900
type=00000004, cksum=000074A5, address=10800000, length=002A2B61
type=00000006, cksum=00000006, address=10800000, length=00000000
iMX6.QNX.LoadImage.ready: 0x0F715A7F
Enabling only 1 CPU
L2 cache enabled
CPU0: L1 Icache: 1024x32
CPU0: L1 Dcache: 1024x32 WB
CPU0: VFP-d32 FPSID=41033094
CPU0: NEON MVFR0=10110222 MVFR1=01111111
CPU0: 412fc09a: Cortex A9 MPCore rev 10 792MHz
Board version: PQ/3 v19
Detected i.MX6 Solo/DualLite, revision TO1.3
PLL1 - System : 792MHz
PLL2 - System Bus : 528MHz
PLL3 - OTG USB : 480MHz
PLL4 - Audio : 36MHz
PLL5 - Video : 339MHz
PLL7 - Host USB : 480MHz
PLL8 - Enet : 100MHz
IPG clock : 66000000Hz
IPG per clock : 66000000Hz
UART clock : 80000000Hz
CSPI clock : 60000000Hz
AHB clock : 132000000Hz
AXI clock : 198000000Hz
EMI_SLOW clock: 19200000Hz
DDR clock : 396000000Hz
USDHC1 clock : 198000000Hz
USDHC2 clock : 198000000Hz
USDHC3 clock : 198000000Hz
USDHC4 clock : 306580644Hz
ENFC clock : 24000000Hz
System page at phys:10010000 user:fc404000 kern:fc404000
Starting next program at vfe056b84
cpu_startnext: cpu0 -> fe056b84
VFPv3: fpsid=41033094
coproc_attach(10): replacing fe073244 with fe089dd4
coproc_attach(11): replacing fe073244 with fe089dd4
Welcome to QNX Neutrino on the Freescale i.MX6 MIBSTD2PLUS_CPU (ARMv7 Cortex-A9 Core)
00:00:00.213 [Info] [tsd.mibstd2.hmi.anim.cpp] [PERF:0xd773bf:IO0] iMX6.earlyRVC.ready
00:00:00.214 [Info] [tsd.mibstd2.hmi.bootanim.j5] cda start
00:00:00.216 [Info] [tsd.mibstd2.hmi.bootanim.j5] cda: graphics init
00:00:00.255 [Info] [tsd.mibstd2.hmi.bootanim.j5] cda: graphics init complete
00:00:00.278 [Info] [tsd.videocapture.control] All rvc libs loaded successfully!
00:00:00.280 [Info] [tsd.mibstd2.hmi.bootanim.j5] initialize video capture complete
00:00:00.281 [Info] [tsd.mibstd2.hmi.bootanim.j5] mmap_device_memory successed
00:00:00.281 [Info] [tsd.mibstd2.hmi.bootanim.j5] [PERF:0x11c8ab6:IO0] iMX6X.screen.start
00:00:00.282 [Info] [tsd.mibstd2.hmi.bootanim.j5] try to load screen-mgr.so
00:00:00.282 [Info] [tsd.mibstd2.hmi.bootanim.j5] watching_thread started
00:00:00.284 [Info] [tsd.mibstd2.hmi.anim.cpp] Startup Info Thread started.
00:01:00.010 [Info] [tsd.mibstd2.hmi.bootanim.j5] applyCSCGamma() r: 0xffff g: 0xffff b: 0xedff
00:01:00.010 [Info] [tsd.mibstd2.hmi.anim.cpp] startup container mapped to addr 0xffde0 (length = 1048576)
00:01:00.056 [Info] [tsd.mibstd2.hmi.bootanim.j5] cda: splash image posted.
00:01:01.129 [Info] [tsd.mibstd2.hmi.bootanim.j5] cda: splash image posted.
00:01:01.257 [Info] [tsd.mibstd2.hmi.bootanim.j5] cda: splash image posted.
00:01:01.450 [Info] [tsd.mibstd2.hmi.bootanim.j5] cda: splash image posted.
00:01:01.642 [Info] [tsd.mibstd2.hmi.bootanim.j5] cda: splash image posted.
00:01:01.834 [Info] [tsd.mibstd2.hmi.bootanim.j5] cda: splash image posted.
00:01:03.116 [Info] [tsd.mibstd2.hmi.bootanim.j5] cda: splash image posted.
00:01:03.260 [Info] [tsd.mibstd2.hmi.bootanim.j5] cda: splash image posted.
00:01:03.388 [Info] [tsd.mibstd2.hmi.bootanim.j5] cda: splash image posted.
00:01:03.516 [Info] [tsd.mibstd2.hmi.bootanim.j5] cda: splash image posted.
00:01:03.660 [Info] [tsd.mibstd2.hmi.bootanim.j5] cda: splash image posted.
00:01:03.789 [Info] [tsd.mibstd2.hmi.bootanim.j5] cda: splash image posted.
00:01:03.917 [Info] [tsd.mibstd2.hmi.bootanim.j5] cda: splash image posted.
00:01:04.045 [Info] [tsd.mibstd2.hmi.bootanim.j5] cda: splash image posted.
00:01:04.173 [Info] [tsd.mibstd2.hmi.bootanim.j5] cda: splash image posted.
00:01:04.301 [Info] [tsd.mibstd2.hmi.bootanim.j5] cda: splash image posted.
Unable to access "/dev/hd0" (2)
chkqnx6fs: unable to access '/dev/hd0t177' - No such file or directory
chkqnx6fs: unable to access '/dev/hd0t177.1' - No such file or directory
chkqnx6fs: unable to access '/dev/hd0t177.2' - No such file or directory
fsstate: chkqnx6fs took 0 seconds.
mount: Can't mount / (type qnx6)
mount: Possible reason: Invalid argument
mount: Can't mount /tsd/etc/swap_keys (type qnx6)
mount: Can't mount /tsd/var (type qnx6)
iMX6.QNX.init.ready
on: No such file or directory (/tsd/bin/system/startup)
00:01:05.607 [Info] [tsd.videocapture.decoder] Reset Decoder!
00:01:05.704 [Info] [tsd.mibstd2.hmi.bootanim.j5] Initialization of CaptureUnit and decoder done
please tell me , are my emmc chip is dead? Thank you
These are the worst ~~~~ing instructions ever. They were written by a 5-yr old.
