Results 1 to 3 of 3
    Feb 2018
    Default Injector codes inside eobd read
    Hello, i have a ford transit connect 2003 with the 1.8 tdci and a delphi with the MPC555 microcontroller (not sid). I have replaced injectors and i need to code them, but i dont have acces to a scan tool to code them. i have read the ecu via obd with a galletto v54 (clone).
    Now i need to find the IMA codes of the injector inside the read i have and replace with the new ones.
    any tips on how to find them?
    attached are the Photos of the ecu and if needed i can provide the read ive done with galletto.
    thanks a lot.
    Jul 2020
  3. The Following User Says Thank You to ToyoTom For This Useful Post:
    Turboangelo (27th October, 2020)
    br556hre's Avatar
    imho injector codes shod be in ecu's eeprom. If you have old injector codes, look for them in your eeprom, they shod be one after another starting from gearbox side as nr 1 written in hex. Just overwrite with new ones and you shpd be fine. I'm not sure about checksum.
    On psa edc16c34 it worked smooth no problem.
  5. The Following User Says Thank You to br556hre For This Useful Post:
