Results 1 to 7 of 7
Thread: Kawasaki z900
    Jan 2012
    Germany
    Default Kawasaki z900
    Hello everybody.
    Would anyone have a pinout for this 2018 bike?
    Msop eeprom is a bit difficult to work with.
    Thanks in advance.
    jomberykaso's Avatar
    Sep 2013
    En algun lugar de Chile
    Just use a multimeter and check the continuity If you see the eeprom
    Jan 2012
    Germany
    Should I choose the lowest continuity? I suppose. There are times that some eeprom pin leads directly to some pin of the MCU or goes through some electronic component and I don't know what to do in these cases.
    Sep 2013
    I always remove eeprom before reading.
  5. The Following 2 Users Say Thank You to jomberykaso For This Useful Post:
    robert1232 (1st December, 2020), spantor (12th October, 2020)
    Jan 2012
    Germany
    I know that is wise advice. But with tssop8 it was a bit difficult for me because of the separation of the pins, I imagine msop8 would be the same. Anyway, I have done some practice in tssop8 and it seems that my welding technique has improved a lot. I think I am ready to desolder and solder tssop and similar.
    Only for curiosity. Could there be a problem reading directly from the board? So far all the pinouts I've gotten here have worked very well.
    Landetos's Avatar
    Mar 2013
    Inside EnigmaTool
    Quote Originally Posted by spantor View Post
    Those eeproms may easily loose data when reading in circuit. I always recomend unsoldering to all my clients. It is the best way because in the end it will save you time, money, hedaches and health spent on repairing damaged modules...
    I also recomend to use 3.0-3,3V max for reading and programming of MSOP and VSSOP eeproms...works fine for me and instead of damaging i have repaired a lot of dashes with those type of eeprom chips...
    Live by the rules and die by the rules...
    Thank before you die...
  8. The Following User Says Thank You to Landetos For This Useful Post:
    spantor (1st December, 2020)
  9. #7
    Nov 2020
    North London, UK
    Watch few youtube videos how to disolder, buy replacment chip to practise, Would advise to disolder it and not to read directly from the board. Quite easy to disolder them with hot station, make sure do not overheat the PCB
