Results 1 to 14 of 14
    Sep 2020
    Default 2019 Fort Transit Custom
    Hi i used a Tool called OBD Doctor 500 to change the mileage on 2019 Ford Transit Custom i read the flash saved the original and then altered the mileage it worked fine i then drove the vehicle for around 10 miles and still fine, i have woken up this morning to 4 XXXX on my dash ? can someone explain what this is ? and also can i just flash my original file back on to correct this problem ? thank you
    jomberykaso's Avatar
    Sep 2013
    En algun lugar de Chile
    Sep 2020
    thanks for posting this thread but none seems to have a clear explanation to why it says XXXX or even more importantly a solution to getting it corrected i hope someone had fixed this problem and can share there experience with us
    Feb 2020
    Did you get this fixed ?
    Oct 2017
    your attempting to work on a 30k euro van with a 300euro tool , Dont change your name from Donkey Power,Smok UHDS myt fix the problem
    Jan 2019
    United Kingdom
    Quote Originally Posted by Aislingob View Post
    once its XXXX you cant fix it by doing mileage again, SMOK will not fix it, can only be fixed manually on bench using a hexeditor
    Sep 2020
    Just a update on this, I fixed this problem and it was fixed the following day using the same tool and a method pm me if you want to know as there is a lot of non helpful people on this site that i hope this happens to and they get stuck, for those people who are helpful i would love to share this with you
  8. The Following 3 Users Say Thank You to donkeypower For This Useful Post:
    pulsar2000 (14th January, 2024), sagie1zn (22nd November, 2020), westlo (21st November, 2020)
  9. #8
    Dec 2016
    central uk
    how did you change mileage in the ecu, ? i was woking doing some electrical work at a ford dealer a while ago and a customer was shouting at the technician cause they had checked the mileage on ecu and it didnt match?? lost his warranty not a happy bunny .
  10. #9
    Feb 2020
    You can fix quite easy if you have smok ( needs original flash and eeprom fro similar van I think ) and with m500 I have heard , yes you are right there are some lets say " not so nice " folk on here among some very helpful
  11. #10
    Oct 2017
    Spill the beans Mr Donkey , I can’t wait to hear ur solution ??
  12. #11
    Feb 2020
    There is a way of repairing with the m500 it by using a combination of different cars focus and custom for example . its due I believe to the fact that when you use transit you dont get a full read
  13. #12
    Dec 2021
    hi guys, i have use of obdprog m500 will it correct my mileage on a 2021 transit custom with out giving the XXXX after so many miles?
    thanks in advance
    Matt
  14. #13
    Mar 2023
    Quote Originally Posted by mBarton14 View Post
    thanks in advance
    Matt
    Quote Originally Posted by donkeypower View Post
    Hi I have the same problem can you tell me please how you got this fixed my dash is reading xxxx
  15. #14
    marina_rv's Avatar
    Jul 2010
    Ukraine
    Quote Originally Posted by brendymcn View Post
    write original eep in dash
    please press the little THANKS
