Not sure how you do it, but so pester the picoscope forum
some where, there is 6 giga watts file of everything you can think of
Here, go LEECH here, never looked past first page
https://www.picoauto.com/support/
hows the INFERIOR site you left dk for doing?
Ok
1) give up
2) #swapnostics
3) rent a car
4) what is the issuse?
Ok so
a) what is problem from customer view point
b) problem from your view point
c) what you done?
d) fault codes?
e) timing chain stretched?
F) use a dti gauge?
Fault code?
candles wet?
compression?
cylinder leakage?
service history?
Last oil change - this century or last?
Remove lumpystick sensor see if get P0340?
im still in bed
If it’s 20 years old, that would mean milliniom bug installed.
can you pull front end off, check timing manually.
ok word of the day ‘revolve’ the candles are wet, but you have squish in the pots
wet candles
blocked exhaust (full of dk thanks?)
no/not enough spark
too much fuel - thinks its as cold as ice - temp sensor - air flow meter/map
not enough squish. Minmimin of 150 psi?
blocked air filter
throttle pedal stuck open
some put paint stripper in tank - melted end off injections
On topic
if you use cylinder leakge test will confirm if bent valves
The injection timing is out, thats why I was looking for cam/crank
Ok, OFF/ON TOPIC.
you hit a rock with your petrol mower the flywheel shears an aluminium woodruff
key, knocks timing/magneto out
ON TOOIC
SHERE crank sensor location?
